Click/clunk on manual 4406 after lifting off the throttle | Ford Explorer Forums
Hokie
Hokius Maximus
Denver, CO
'98 TJ Sport
My manual 4406 seems to be developing an interesting characteristic.
When I let off the throttle, sometimes it will click, sometimes it will clunk. If I hold the shifter I can feel a solid click/clunk to go with the noise.
It seems to do it in 2WD and 4WD. I pulled the front D shaft and it still clicks/clunks (I was thinking maybe a front u-joint).
Any ideas? Maybe a bad bearing somewhere that is causing some drag on a shaft (and the change from power to coast causes an audible clunk)?
:confused: :scratch: :crazy:
Mine does the same thing- I haven't worried about it. It only does it under certain conditions. Like if I am at highway speed, goose the throttle then let off, I get a clunk.
Yeah, I can sometimes make it happen by quickly letting off the throttle. Vice versa, if I gently glide off the throttle it won't happen.
Wierd - What do you think would be causing this? My t-case is pretty low mileage
Obviously Ford wouldn't let something like this go into production on an F-150. I was first thinking it was maybe caused by having a non-vacuum disco'd front end (maybe the F-150's don't spin the d-shaft) but I pulled the front d-shaft and it still does it AND you have a vacuum disco and it does it.
Whats different about our setup and the F-150 setup?
I was wondering if the close proximity of the shifter to the body allows for more noise transfer?
And, I am not sure if it still makes the noise, I haven't paid attention since the swap. I will check that out tomorrow.
ANy body ever come up with a conclusion to this noise? Mine dose the same thing.
sounds like it could be a broken transmission mount but i could be wrong, also could be different mounts
