ROBinGa
- February 16, 2014
- Ga
- 2003 Explorer XLT 4x4 4.6
So I've been reading the threads past few days about the recirculation door issue for Max AC, and also exterior air inlet. Don't think we are having the issue with the Max AC problem. But rather the selector switch to the far right that controls where the vent, floor, defrost, etc. air flow is diverted doesn't seem to change airflow source. If it's set to all vent or all defrost the air still comes out of the front vents. I do have all four speeds from fan selector and it does change in volume from 1 to 4. Also the temperature selector is working so that heat comes out when in the red and cool air when in the blue. So is there a fix for what I am describing with the selector switch on far right not changing where the air comes out? I haven't done anything at this point other than diagnose that the selector does not affect where air flow blows from. Update actually I think air is coming out of vents and defrost and floor all the time regardless of where the selector shows it should be coming out.
