hawkk72
- June 3, 2008
- Greensboro NC
- 1999 Eddie Bauer
On my 1999 Eddie Bauer I have replaced the blend door actuator (new part) and the climate control unit (used, supposed to be 100% operational). Still no response from the actuator. Also, air just coming out defrost vents. I found an unconnected vac line under the hood which led directly to the vacuum resevoir but after connecting it there was no change. Checked the resevoir and other vacuum line and all seemed to be connected and leak free. My question: Could all of these problems be symptomatic of a bad climate control unit? How can the unit be checked for correct operation? I understand there are "pin" tests to do but I have no idea where to get the right information on exactly how to do this. By the way I tested the controller for error codes and saw 024 and 025 which are blend door actuator codes. I am forced to try and correct my vehicle problems myself as I was recently notified that my job would soon be eliminated. I would appreciate all the help you can give.
