For a while now i've had a clunk ( sometimes almost like a bucking) coming from the rear and sometimes the left front of my 96 explorer 4x4. This is only during acceleration and none during deceleration and it only happens every so often. More in the back than the front. I greased the front and back slip yoke liberally and no change. I checked the u-joints on front and back driveshafts and there was visibly no play. There is no play in the front or rear differentials. I removed the differential cover on the rear and everything seemed okay. There is alittle play in the rear output shaft on the transfercase. I really don't have any idea so hopefully you guys can shoot some out to me. Thanks alot!!
**Also we had the truck on stands on the back and tires locked down on the front and had it in drive up to a good speed and it did not clunk. Is the front axle supposed to spin with it only in 2wd? My boot on the drivers side cv joint has pulled back and grease leaked out. It does not click or grind on turns at all no matter how sharp they are but perhaps if it was clunking or bucking on that cv joint would it travel the drivetrain all the way to the back? Sorry for the long novel I wrote but I am clueless to what is happening. Thanks again.
