missbehavin
- June 26, 2003
- Punxsutawney PA
- '97 Sport
Attempted to change ball joints on a '97 Explorer Sport 4-wheel drive today. Having all the tools is a much needed thing but started the task and took the wheel off then the brake pads and rotor off and took the lower nut off the ball joint but never got it apart. Took the bolts which hold the front shaft to the spindle off and took the large nut off the shaft in front off but could not get it to separate. Did not have a press to push shaft out of spindle.So after much frustration decided screw it. Bolted everthing back and started to back out and it had a loud whining noise in the front end . First I rechecked everything and it sounded like rubber screeching but seen nothing and retightened the shaft nut. It sounded actually like when the hubs try to lock in when not needed as described in your forum. AFter tightening nut and making sure all was good drove vehicle some then put it in 4 wheel drive as described in your forum and seems problem resolved itself. Well all is not well.... Went into town and got gas and pulled forward and parked vehicle and when backing out I heard a large clunk and stopped ,turned left to pull out and another loud clunk and a feeling as if something was binding and not letting us move. Pulled off the side and tried to look as much as I could but dark but still tried to feel and see and listen as turn the wheel from side to side but seen nothing. Pulled forward and back and once in a while you could tell it was starting to act like it was binding again .........so after this was going on for a few minutes we see that for some reason it got itself into 4 High and am certain at least as we remember did not put it in 4 High........but anyways after taking it out of 4 High we attempted to the forward and reverse and turning of the wheel from left to right and did not hear noise again. Got the X home and put it into 4 High and never heard noise. Am curious if it sounds like a brake grabbing or something binding......am not certain what else it could be when nothing was truly disassembled to create this???????????
