Clunk When Braking | Ford Explorer Forums
Clunk When Braking
djsk8r33
NJ
'91 4DR XLT
exactly as the title states.
whenever i brake, i get a clunk. just below my feet it feels like
if i press the brake a few times, itll happen the frist 2-3 times then after that it wotn happen.... drive some 25 feet and itll clunk
any ideas. nothing is loose underneath
more like a clunk, or some sort of bang
Sure sounds like radius arm bushings...I'm on my second set, ready for a third (240,000mi). Do a search for this item, you'll find plenty of threads.
Could also mean that your radius arm brackets are broke. Mine had shattered. Got a new one from ford for 35 bucks.
A clunk when braking definitely sounds like a Radius Arm problem although a bracket could be broken worn bushings would be the most likely culprit.
im no chevy guy, trust me i know what radius arms and bushings are. i just replaced my bko's bracket, arm, bushing.
the arms and brackets are in good shape, maybe its the bushing. i will change them out tomorrow
it is deffintly the radius arm bushing, its starting to do it at quick hard turns. somehow the rivets are still in the bracket so i think i will replace em later in the week
