Just when you do replace them, make sure you have the drive shaft oriented the say exact way it is now, otherwise you will definitely have to get it rebalanced. Apparently they are balanced while on the vehicle, so that's why.
I'm surprised somebody who knows more about this or has any other ideas hasn't chimed in.
Good luck!
The muffler bearings are also balanced on the vehicle.. .. ..
Sh*t I need to go get mine balanced.![]()
I tried looking up the drive shaft thing, can't find it. I guess I was hallucinating. :scratch:
This is the weirdest thing, I swear I can even see the picture where the person drew lines on it.
here's what my ford CD says:
1. Remove driveshaft as illustrated in this section.
2. Scribe alignment marks on the driveshaft slip-yoke and the driveshaft tube to ensure proper U-joint phasing when reassembled.
3. Remove the driveshaft slip-yoke boot clamps with the end cutter pliers as shown. Discard the driveshaft slip-yoke boot clamps.
4. Remove the driveshaft slip-yoke boot from the driveshaft tube neck and the driveshaft slip yoke. Pull driveshaft slip-yoke off driveshaft stub shaft splines. Discard driveshaft slip-yoke boot.
5. If the driveshaft slip-yoke boot is found to be cracked or split, the grease should be checked for contamination. If driveshaft was operating satisfactorily and grease does not appear to be contaminated, continue with the installation procedure.
6. Check the lubricant for contamination by rubbing between two fingers. Any gritty feeling indicates a contaminated driveshaft slip-yoke and stub shaft. If the grease appears to be contaminated, inspect the stub shaft and driveshaft slip-yoke for wear. Clean all foreign matter from the driveshaft splines.
Installation
1. Install the driveshaft slip-yoke boot with the small diameter facing the splined stub shaft end. Push the driveshaft slip-yoke boot as far as it will travel on the stub shaft.
2. Install a new small driveshaft slip-yoke boot clamp and crimp the driveshaft slip yoke boot clamp using Keystone Clamp Pliers T63P-9171-A.
3. Pull the driveshaft slip-yoke boot toward the driveshaft and coat the stub shaft splines with Premium Long-Life Grease XG-1-C or -K or equivalent meeting Ford specification ESA-M1C75-B.
4. Fill the driveshaft slip-yoke boot with approximately 10 grams (.36 ounce) of Premium Long-Life Grease XG-1-C or -K or equivalent meeting Ford specification ESA-M1C75-B.
5. Slide the large slip-yoke boot clamp onto the barrel of the driveshaft slip-yoke before assembling shaft together.
6. Align the driveshaft slip-yoke and driveshaft tube using the alignment marks scribed in Step 2 of the Removal procedure. Push the driveshaft slip-yoke onto the stub shaft.
7. Remove all excess grease from the driveshaft slip-yoke boot and driveshaft slip-yoke. Position the driveshaft slip-yoke boot over the groove.
8. Move the driveshaft slip-yoke in or out in order to position the slip-yoke about 25-38mm (1-1.5 inches) from the collapsed position.
9. Using Keystone Clamp Pliers T63P-9171-A, crimp the large driveshaft slip-yoke boot clamp.
10. Reinstall driveshaft as illustrated in this section.
I think I know the thread you are talking about but it's not balance, but yoke alignment their talking about.
You do want to mark the slip yoke so that you get it back on in the same orientation.
Many drive lines have the splines "keyed" to keep the u-joints at 90* to each other, this one however does not.
You want the u-joints like this ++ not like this X+ or it'll bind.
