clunking noise in front passenger side wheel | Ford Explorer Forums
djwink
2000 ford explorer
I have a clunking noise in my front passenger side wheel, most noticeable when going over bumps or turning the wheel towards the right. How can I tell if this is a tie rod end, ball joint, cv joint, etc. I jacked the car up and tried moving the wheel at 3 & 9 o'clock and 6 & 12 o'clock positions and didn't notice much movement. Also put a bar under the wheel and tried to lift, but nothing noticeable. How do I pinpoint the bad part. I hate to just start replacing parts. This is a 2000 explorer.
check your front sway bar end links. if they're bad/broken/missing it will be obvious.
