alollich
- September 2, 2002
- Grand Praire, Tx
- 1994 Sport
Well the time has come to replace the clutch in my sport. I searched the archive and found most of the info I needed. However, I still am unsure on a couple of things. I am going to replace the slave cylinder and have never bled one before. Can I put the new one on and use a vacuum pump to draw the fluid through the entire system or do I need to bench bleed it first and then bleed the entire system? Second, does anyone know the Ford part number for the three little seals on the top of the transmission that always leak? Lastley, does a new slave from Ford come with the throw out bearing or do you have to buy it seperate? Thanks for the help!
