SE7EN
- September 26, 2008
- College Station, TX
- 91 XLT
my clutch slave cylinder went out this last sunday i spent all day monday and tuesday replacing it, i tired to bleed it good before i put it all back together but i guess i did not bleed it to well, because it is still haveing problems going into gears i have to push harder then you normaly have to, to put it in gear. also the store had told me to put "gear oil"? (because they could not find what fluid it needed in there computer and i wasnt sure myself and then when i drained it i noticed it was red so i figured id just put it in because i dont have any other vehicle right now and i just need it running) in my transmission i am going to put mercon V tomorow when i wake up before i go to work, would the gear oil have any effect on the shifting?
i have tried bleeding it a few times since then but it didnt make a realy big difference, ill have my wife pump it till it gets pressure and then open the bleeder valve, and it seemed liked it was bleed but maybe im doing something wrong, i did this while the vehicle was started, im thinking im gona spend the $40 and have somebody do it but please somebody tell me how to do it right so i can save my money.
thanks
thanks
