pabloh36
- September 15, 2009
- steamboat, co.
- 2001 sport 4x4 manual tra
okay, as I understand itthe clutch slave is in the tranny?? and the master is on the fire wall?? I can't see a thing. there's the big round vaccuum whatever and the main fuse box so you can't even see it. under the dash either. anyway the other day I had plenty of pressure but no pedal. checked the res and it was dry. great huh? refilled and the clutch pedal has plenty of pressure but you have to pump it to get in gear. also it disengages immediatly with no travel from the floor. air problem?? also it appears to have no leaks cause it has lost nuthin since refill. does the fluid evaporate? so you need to check it often? I've been bad about checkin it. sorry about the lenth of this. any help appreciated.
