torqlox
- April 6, 2007
- Cape Coral, FL
- 99' Explorer XLS
Well, my 2000 Sport OHV has been acting up since I replaced the upper intake gaskets, DPFE, IAC, and EGR valves & hoses. Before these replacements, the truck was giving off a P0171 (Lean Bank One) code which is a common problem with leaky plenum gaskets on these trucks. The problem is that now it's throwing a P0301 (Cylinder #1 misfire), and I can't seem to detect the root of the problem.
Parts replaced within the last 6 months:
Both upstream O2 Sensors
Plugs & Wires
Coil Pack
IAC Valve
EGR Valve
DPFE Switch & hoses
Fuel Rail Gasket
Upper Plenum Gasket
I have not replaced the very lowest intake manifold gasket yet, but then again I have not heard any "sucking" sounds indicating any violent vacuum leaks. Injectors were cleaned and pulse tested well. Any ideas on where to go from here???
Plugs & Wires
Coil Pack
IAC Valve
EGR Valve
DPFE Switch & hoses
Fuel Rail Gasket
Upper Plenum Gasket
