Daisywheels
- July 1, 2014
- 1999 XLT XP SOHC V6
So I have this P0171 Code. This code showed up after I took the intake manifold off, to repair a wire to the cooling sensor. Wire repaired, cooling code gone, replaced with P0171. Vacuum hose are strong, no sign of leaking
Had to re-install an old EGR valve due to forcing the pipe and forcing the intake upper plenum into place (I think).
How to solve this puzzle:
a) You need to reset and torque down the upper plenum
b) Both EGR valves are bad, however one makes the rough idle worse
c) See b) and look at EGR pipe also
d) Upper plenum gaskets
e) Who the hell really knows - add an answer!
Best answer earns 5 stars!
-DW
-DW
