lonestar
- August 29, 2001
- lou,ky
- 91 XLT, 02 XLS
I have a 95 Ranger 3.0 and am trying to figure out what type of code reader I need. I believe it has a OBDII connector, but is not fully compliant, meaning it has a cross between OBDI and OBDII.
from obdii.com
"If your vehicle has this style connector, but doesn't have these pins populated, you probably have a pre-OBDII vehicle. To add some confusion, even having the connector with the contacts shown above is not a guarantee of OBD II compliance. This style connector has been seen on some pre-1996 vehicles which were not OBD II compliant."
SO what scanner do I need. A older $35 OBDI scanners won't fit the connector. But I don't believe a OBDII reader will read OBDI codes.
Can you read these codes with a meter like in older OBDI?
Would anyone know which wires in this non compliant OBDII connector correspond to an OBDI connector?
from obdii.com
