Coil Spring Spacers? | Ford Explorer Forums
redwood
Columbia, MO
1997 Ford Ranger
I was wanting to get some opinions on coil spring spacers. Do they actually give you 2 inches of lift? What can you guys tell me about them.
Thanks Much!
redwood
most likely they'll bring you to about stock height maybe a minor lift above..simply bekuz they cause a slight compression of the coil..and if thers been any sag on the coil whih ther most likely has..2 inches is rather minor..its prolly a better bet tojus get the 2 in lift coil..or get OEM coils and then put in the spacer
Early 90's F150 2wd..they are not spacers they are actually the lower spring seats. THey don't give a full 2"s, more like 1 5/8" lift :)
I got mine at a pull a part yard for 10 bucks or something like that. Good deal if I ignore the fact I almost barfed it was so forkin hot that day LOL
