magnet56
- October 23, 2008
- Greenville, NC
- 97 XLT
I have a 1997 Explorer 5.0 all wheel drive. On mornings when the temp. is below 38-40 degrees F. the fuel pump will come on and continue to run as long as the key is is the on posistion. The engine will not even attempt to start just spin over. When the temp warms up above about 41 degrees the fuel pump will come on and shut off and the engine will start.
Here is another thing to consider. Anytime you attempt to start the engine ( when the temp is cold or hot )you have to wait for the fuel pump to shut off before it will start. If you attempt to start before it shuts off the engine just spins over like its not even firing. The fuel pump always runs about 20 to 30 seconds which I know is longer than it should. The reason it wont start on a cold day is because the pump will not shut off.
I have dropped the tank, cleaned it out, replaced the fuel pump, strainer, fuel pump relay, and fuel filter. When the engine does start it always runs beautifully. Any help would be appreciated.
