SaltCoveredFord
- January 15, 2010
- Northern VA
- '99 Eddie Bauer
(I hate creating new threads but my exact issue doesn't seem to be in any of the others I've read.)
So I've posted previously about my battery drain issues I had last winter. The issue was worked around by pulling the fuse that handles the GEM (and power windows/instrument cluster) when I don't have the truck running. Weather warmed up - no longer had to pull the fuse. As soon as it got colder, the first time the truck hesitated on startup I started pulling it again.
Now it seems, even with pulling this fuse, the truck is struggling to start on cold days. I've been reading through the forums and used the advice to cycle the ignition off and on to get the truck started. It has worked, though it seems to take several (if not 10+) times cycling to work. And with the weather getting colder by the day, i'm wondering for how long it will work.
I spoke with my brother, who used to be a ford service manager. He explained to me that when I cycle the ignition the fuel pump builds up pressure and likely what is happening is so many cycles finally builds up enough pressure to start the truck. I guess the assumption is there is an issue with (or to/from) the fuel pump. He also asked when the last time I changed the fuel filter was - and having taken the truck to a quick-lube place for all of it's oil changes I cannot remember when/if I had been asked (or agreed) to have the fuel filter changed. That will be one of the first things I'm planning on checking.
I also see all kinds of posts here about gaskets possibly needing to be replaced, etc and the fact that they are an issue when it is colder (because summer = expanding gaskets?). The truck is up to about 130k miles, so a fuel pump isn't out of the question - i was just hoping to get more info before I head to the dealership. My fear is they'll drop the gas tank, do their testing, and everything will looks just fine.... until I try to start it the next morning.
Any insight would be appreciated,
-Salty
-Salty
