BillF
- December 25, 2015
- Bishop, CA
- 1999 Explorer 4.0 SOHC EB
Hi Everyone,
I have a cold weather no start issue with my 1999 4.0 SOHC Explorer. This has been an issue for a few years now during colder periods of weather. I searched through all of the forums regarding similar issues, but never found an issue or solution that exactly matches mine.
The main problem is with fuel delivery. During colder days 20 - 30 degrees F, I do not hear the fuel pump prime and no fuel is at the manifold rail check valve. It will try to start with ether sprayed in the throttle body, but is dies quickly. This tells me the spark is OK. It is producing no OCD codes and of course when the dealer looked at the truck, it worked fine. It cranks strong, has a new fuel filter, plugs and wires, fresh gas and overall just does not activate the fuel pump. I have followed the no start procedure for the fuel pump issue posted on this forum.
I jumpered the fuel pump relay (#9) and the pump did not come on. I put in a new fuel pump relay and same problem. I detached the connection on the wiring (sending unit C311?) near the gas tank and it looks good. This connecter only had 2 pins, did I find the right one? The crankshaft positioning sensor looks OK during a visual inspection.
The check engine light is illuminated when the key is on and goes off while attempting to start the truck. Does this rule out a PCM issue? The PCM fuse and relay are OK. A full open throttle during the attempted starting does not do anything, either. The inertia switch is pushed down and never was tripped.
The only noise I hear before the starter kicks in is a slight hum from the passenger side kick board where the inertia switch and PCM are located.
It only appears to have this issue in colder weather. It was fine all spring, summer and fall. About a week ago when it was about 40 degrees F, it would not start. I put a hair blow dryer near the thermostat for about 15 minutes and then it started. 4 days later on the very next attempt to start, no fuel pump prime/hum sound, but it was only 25 degrees outside and has not started since and the days are still only in the 20's and low 30's. I live at 5900 foot elevation.
I thought it may be the ETC sensor or IAC, but it appears from other members posts neither of them would create a no start condition. I tried to heat up the area around the thermostat on a 25 degree day, but it did not work this time. In the past, it would start the next day or if I let it sit outside in the sun. So I next ried to use a little 1500W heater near the passenger kick panel to heat up the PCM and inertia switch area to approximately 60 degrees with no success. I have read a lot about intake manifold leaks, but would this cause a no start condition? The truck runs just fine when it finally starts.
I am almost certain that it is not the fuel pump because of identical cold start issues in the coldest months from 2014 until now. How could a fuel pump sporadically work for 2 years? Does anyone have any ideas, because a trip to a mechanic will likely replace parts that are not really failing and cause even more frustration. What could be causing the fuel pump not to activate in cold weather? Thanks!
