Are you going to re-use your stock rocker arms? Or are you going with the upgraded ones from Delta Cams? Reason I'm asking is this will affect the length of the pushrods you order.
Stock rocker arms: order 5.550" pushrods
Delta Cams Rocker arms: order 5.525" pushrods
In addition to that they're going to need the year. make, and type of motor you have. (i.e, ford 19xx 4.0l OHV v-6)
If you're wondering what the Delta Cams rocker arms are...basically there is a durability issue with the stock rocker arms. There is a cup where the pushrod sits and that cup as well as the pushrod gets worn. This causes a valve tapping like noise in older 4.0's that you might be familiar with. What the delta cams rocker arms have is a hardened steel cup pressed into them so that the pushrod doesn't wear on the rocker arm. The delta cam rocker arms are another good investment in the longevity of your motor but not a requirement....I think a set of them runs about $250
