Condensation in headlight housing | Ford Explorer Forums
ERIC
Wilmington, NC
'96 XLT
Two years ago I installed new headlight housings in my 96 as the originals had badly fogged.
A couple of months ago I noticed the housings were showing a lot of condensate on the inside of the lenses. (This is a street vehicle only these days....no offroading.)
I pulled the grill and turn signals this a.m., and noticed both headlight housings have a small plugged hole on the bottom. (Headlights are still in place...did not remove.) Is this a weep hole...and should it be open? I pulled the plugs on both in hopes of the insides of the housings drying out, but frankly I can't imagine these holes should be left open.
I cannot find any obvious cracks or openings that would be allowing moisture to build up inside the housings.
Anyone have an opinion on:
1) Should I leave the "weep hole" plugs out?
2) Why am I getting moisture inside the housings to begin with?
Eric in NC
When this happened to my diamond clear headlight lenses, I drilled a hole in the top and ran a small rubber hose from the hole to under the hood. The hose was siliconed in place. This solved my problem and has performed flawlessly for a long time.
Good luck .....
Thanks, Al.
I have now decided the seal between the lens and housing has deteriorated (these were aftermarket replacements.) So I used marine grade silicone sealant to seal the join. That plus swabbing out the moisture inside the housing will hopefully cure it. I think I better put the weep hole plugs back in. If all this fails, I do think I'll silicone on a tube up top as you did. I'd thought about doing something like that, but wasn't sure it was a good idea. Nice to know someone already had success with it.
Eric in NC
I would keep the plugs out for a little while and run the lights to heat up any moisture in the lense. The weep hole will allow that moisture to escape. Then replace the plug.
Thanks JP for the suggestion...but I've got it all buttoned back up now. And it looks like I took care of the problem. But if there is any remaining fogging, I'll try pulling the bulb assembly and letting it sit in full sun for a while.
Sure hope I don't have to dissassemble the whole grill again! :fire:
