thanks but thats the whole kit, i just want the adapter...
Then you don't want a better performing intake. ( Not that KKM crap either, as it reuses the stock intake tube.-see below )
ok so i have a 99 xlt v8 and it has been brought to my attention that there is a company out there that makes an adapter that goes onto the stock intake tube thing (not sure what its called) so that you can attach a cone air filter and get the same performance as a cold air intake for much cheaper. can anybody point me in the right direction to find one of them please? thanks
Not gonna happen. Yes, the cone filter does play a big part in the airflow improvement in a CAI. However, replacing the restrictive, accordian like stock air intake tubing with a smoother, largeer diameter tube/bends is a critical factor.
Your best bet is to just save up and buy a real CAI, like the K&N FIPK, that's been engineered and flow bench tested to optimize air flow.
However, a reasonable low-buck alternative would be to make your own CAI with a cone filter and PVC pipe and fittings, or thin wall aluminum tubing, if you can find it. Do NOT use dryer duct or something similar. Also, be sure to keep the I.D. of the pipe as smooth as possible. Maybe use some expoxy to smooth out the transitions after the PVC cement dries on the joints.
Really though, unless you already have the filter laying around, all the parts/supplies will end up costing about half as much, or more, as a commercially made complete kit.
Also, don't forget: After installing a CAI kit, you'll need a computer tune for it to really work well. Otherwise it will tend to run too rich, and waste fuel.
