steppizz
- January 6, 2005
- humarock ma
- 96 XLT, 04XLS
96 Explorer XLT
I see a lot of great info on this board I hope someone has seen this problem before. Fuse 26 on the interior fuse panel keeps blowing. this fuse serves the backup lights and also some portion of the 4x4 system. Rang out the backup lights so I think the problem is related to the 4x4 electric shift system. Following a lot of threads on the board I started to take apart the electric shift motor. When I pulled apart the connector I found that the terminals inside the connector had corroded to the point where the pins had broken off inside the connector. After Verifing that the bushing inside the mechanism was OK and the motor was operational I went about individually splicing and sealing the 14 wires from this connection. I disconnected the battery to reset the computer and tested the repair . The 4H light came on steady but I didn't verify if it was actually engaged when I tried to switch to 4L both the 4H and 4L lights started blinking for about 10 seconds and then the 26 fuse blew again. After replacing the fuse I couldn't get either light to illuminate and the fuse seemed to blow as the gearshift lever was moved by neutral.
Any advice on what to look at next. Im looking for testing proceedures for the Transfer Case Shift Relay and also for any feedback on additional items which may be the related to the problem.
Thanks .
Thanks .
