BTR
- April 1, 2011
- MARIETTA, GA
- 2000 XLT 4.0 SOHC 4DR 2WD
The control arm bushings in the front upper control arm are made out of a metal casing with rubber inside. New bushings come as one piece assembly, i.e., the rubber part is already inside the metal casing.
To replace the bushings by removing the entire assembly (metal casing and rubber part), what is required in order to remove the metal casing from the control arm? Can it be removed with a hammer? Or, does it require a press... in order to press the metal casing out of the control arm?
Thanks for your help!
2000 Explorer 4-Door 2WD 4.0 SOHC
