wollimann
- July 19, 2011
- Europe (Germany)
- 1997 4.0 sohc xlt
VIN: 1FMDU34E8VUA67356
one piece UCA design
little front lift by adjusting torsion bars
longer rear shakle
For quite a while i have problems with the front alignment of the Ford Explorer 97.
It is not possible to reach the OEM camber settings with new camber bolt kit.
While I was searching for upper ECCENTRIC CONTROL ARM CAMBER BUSHINGs, I noticed this here.
http://www.jcwhitney.com/professional-grade-eccentric-control-arm-camber-bushing/p2023244.jcwx
But unfortunately they are not available for the Ford Explorer.
They look very similar to the Explorer bushings, if i have the dimensions,
in that case I could draw some comparisons.
My Ford Explorer upper control arm bushing measurement:
A: 2 inch
B: 1.847 inch
C: 0.283 inch
D: 1.43 inch
If you could help me in this case, I would be very happy!
Maybe someone has a link to matching accentric bushings?
Thank you in advance
Wolfgang
longer rear shakle
A: 2 inch
B: 1.847 inch
C: 0.283 inch
D: 1.43 inch
Wolfgang
