ExPlOrErImPoRtS
- March 2, 2008
- 2002 4.6 Limited
I have 2002 ford explorer 4.6L V8 awd 4x4.
I have a coolant loss issue. Over last month have been loosing coolant. Could not find leak. Added dye into coolant. Found no leak outside motor with uv light. Did find coolant in the oil. oil cap has the white goo in cap. Green coolant drops on the dip stick in oil. Runs Great, no smoke out tail pipe. I hope its not head gasket but might think is a intake manifold gasket leak or blow out of o ring. I have the updated plastic manifold was replaced at 90k. 160k miles on the clock now.
what do you think I should do.
large paper weight?
large paper weight?
