reomack
- September 11, 2013
- 2002 ford explorer
The truck has been losing coolant at a slow but steady pace for a while. Recently it got much worse, so bad I had to do something. I couldn't find the leak and did some research which indicated that the leak might be in the heater tube that goes under the intake manifold to the rear of the engine. Only way to check is to remove the manifold. I have it off now and while the tube is rusty and will be replaced it wasn't leaking. Examining the manifold carefully I found that the passenger side rearmost mounting tab/ear is cracked and that this is also the area of the leak. The rear of the passenger side head is clean, looks like it had been steam cleaned as a matter of fact. However, looking at the manifold, the cracked ear looks like it would still clamp to the head properly as the crack is on the outside of the ear rather than being cracked in a way that would prevent pressure from being applied to the gasket. My question is am I taking too much of a chance reusing this manifold or should I buy a replacement? Any one ever have this exact problem and if so how did you resolve it?
