alaskan-xplorer
- November 14, 2005
- Juneau, Alaska
- 1993 XL
Hi guys, I had a question on what I hope is just a coolant leak. I have a 93 xplorer with around 120,000 miles on it. The truck was very well taken care of by the previous owner and is in immaculate shape. At 100,000 miles, it had a head gasket job done as well as new cylinder heads. The truck runs fine, but off late I've been loosing coolant from the reservoir. I fill it up till the cold fill line and within a couple of days of driving, the reservoir is empty. I've even filled the reservoir and the radiator itself, but the level is still going down. I've not noticed any puddles underneath the engine. I was wondering if that means I've merely got a small leak I'm not noticing or if this means I need another head gasket job (HOPE NOT!!!). My old bronco needed new head gaskets, but that was clearly visible by dripping under the engine as well as smoke from the engine when the leaking coolant hit the exhaust manifold, but none of that is happening in my explorer. Any help greatly appreciated! Thanks.
