I suspect your mechanic is right about the water pump. Mine started losing coolant, but nothing in the oil. I noticed water/coolant on the alternator that had leaked from the weep hole. A simple pressure test will settle that for you. It's not a bad idea to change the timing chain and guides if your over 100K or there is any noticeable wear, the labor will be minimal since it all has to come off anyway. Another thing to do is the spark plugs, since the intake needs to come off or again, there's really not any extra labor to change them if there any where near needing replacement. The good news is, the 3.5/3.7 NA is pretty solid outside of the water pump, so your likely in good shape once this gets sorted out!
