DP96XLT
- November 29, 2019
- New Berlin, WI
- 1996 Explorer XLT 4WD
Ok guys, I did some searching, but there is less than ideal info, so I figured I would post up here...
1996 XLT 4DR 4WD 4.0l V6 with 44k miles on it now. I just bought a Curt 13106 Class III hitch and should have it in next week. I don't do a lot of towing, but as it stands I might be doing some at the end of the month (3500lbs or so for maybe 150-200 miles).
I am also redoing the cooling system in the next few weeks (leak in the radiator where the upper transmission cooler fitting is leaking coolant, not taking chances it is just a seal with a 24yo plastic end tank), so that means new radiator, new coolant hoses, new thermostat, new waterpump (might as well at 24yo).
First off, any recommendations on brand/model for radiator/waterpump? ie, are any "head and shoulders" better than the rest for both longevity and performance?
Next, what would be my best bet for an extra transmission cooler? I drive in the cold of Wisconsin, so I would believe I don't want to bypass the cooler in the radiator, but do I want to add a thermostatically controlled valve to the auxiliary cooler to make sure it doesn't cool the transmission fluid too much? I already run synthetic transmission fluid. All other fluids are also all synthetic as well.
I just want to make sure I am able to tow properly without worrying about damaging anything short or long-term.
