sze kan
- January 10, 2018
- Philippines
- Explorer 2012 3.5L V6
Hello guys,
been trying to figure out this problem but i cannot seem to find what it is... so basically i have put brand new
shocks
lower control arm assembly
stabiliser link
rack and pinion complete
i am still having two issues,
1) while braking or acc, i hear a single "tuk" sound coming somewhere from the front. most noticeable is when the car is in reverse and i need to press the gas in order to move slightly.
2) on uneven roads where both the front tires are moving separately (different road pattern unlike a hump) , there is a wobbly feeling felt mostly on the gas pedal coming from undeneath front middle... its just a feeling with no sound nut the passenger side cannot feel or hear it at all...
it looks as if something which hold both the front tires together is loose or wobbly.. i dont think its the suspesnion.. its something else... i tried to go underneath the car and noticed two very big mounts in the front and another mount in the engine bay... do you guys think those mounts could be the problem? i also didn't replace the strut mounts as the dealer said it still looks ok.... By the way the car doesn't
1) Jerk on changing gears
2) no excess engine movement when i press the gas
3) no noise on turning
4) no noise on speed bumps
shocks
stabiliser link
