Cragar soft 8's | Ford Explorer Forums
Cragar soft 8's
alakers
casper, wyo
'94 4WD
I am having much difficulty finding a cheap 40-55$ cragar soft 8 for my 94 ex. I need 16 inch rims ... preferably 8 inches wide so i'm searching for an 02 ex sport trac, as i know those will fit on my 94. can anyone pleeeaaassseee provide a link to somethin cheap ... ?
Not gonna find them that cheap but here's what I've found real quick on Summit Racing's site:
These have to much B.S. so you need to look at their site and pick out something with 3.75 or 4" B.S. .
$69.95 each wheel 16x8's
Brand Cragar
Manufacturer's Part Number 3977812P
Part Type Wheels
Product Line Cragar Black Soft 8 Wheels
Summit Racing Part Number CRR-3977812P
Wheel Diameter 16 in.
Wheel Width (in) 8.000 in.
Wheel Material Steel
Primary Wheel Color Black
Wheel Finish Gloss
Manufacturers Wheel Series Cragar Soft 8 Series
Backspacing (in) 5.000 in.
Offset +12.00mm
Wheel Construction 2-piece
Beadlock Included No
Beadlock Functional No
Lug Nut Seat Style Conical seat - 60 degree
Hub Centric No
Center Bore Diameter (in) 3.300 in.
Center Cap Included No
Load Rating (lbs) 2,200 lbs.
Valve Stems Included No
Quantity Sold individually.
Yeah, jsut did a quick search for him. He'll need to go on their site and find the correct rim width and specs that he wants. I was just showing that they made them in a 16x8.
Well the less backspace the less rubbing I'll have right?
The least i can find is 4.5" ..
thanks guys
What would look best with that Gen 2 Sport trim that comes out several inches on the front and back?
hhheeeeeeelllppp
Sorry i dont really understand your question ... ^^
But i was wondering if anyone knew, i have 31x10.5x16 .... tires .... the max on the chart specifies using 15x7 or 15x8 rims ... will it rub if i use 16x8's ??? I wouldnt think so, but seeing that specification trips me out !
I have a small lift. (coil spacers and shackles)
what he means is that the trim (fender flares) on the explorers, (especially mine) are massive, about 3 inches. he is wondering what would look best for wheels as they are covered up massively by the shade of the flares.
I would prefer something that is flush with the edges of my trim, yes.
Well if you're lookin for a trade i need to know what you have ... your stock wheels im guessing ??/
I would probably not be opposed to this. I need to make sure i can still, I think my wheels&tires may have been stolen.
