crager soft 8 rims | Ford Explorer Forums
crager soft 8 rims
donfry40
Hudson,Fl
1999 Explorer XLS 4X4
i was looking on sumitt web site and the crager soft 8 rims it has 4" backspace and i have read here that 3.75 backspacing will work but 4" will not, i have a stock 99 explorer xls 4x4 pleae let me know if i need to find another crager soft 8 or if the 4" backspacing will work
well it all depends on the tire you wanna run. Stay towards the smaller sizes and the 4 inch backspace will work fine but if you wanna run something larger then the 3.75 back space would be a better choice to keep the tire from hitting the inside of the fender well.
im looking to run im gonna use my tries for now there 30x9.5.15 but im looking to go with either 31x11.5x15 or 33x12.5x15
I'm not sure I understand your sig...If I've got a 4x4, I don't need to get payed? Seems a little unfair. :D
can i run 33x12.5.15 in these rims and will i have any problems with the backspacing
I ran that size tires on those rims and honly had a slight rubbing at full lock.
