Pump Replaced
FINALLY, I got to the job yesterday, and got the pump (only) replaced.
I followed Koda's recommendations, and got the left side as high as I could (Higher would have been nice, but...) and pulled the left wheel after loosening it while still on the ground.
I had run my fuel down so the needle was resting on the EMPTY mark, so I didn't need to siphon/drain my tank.
I pulled the fuel pump relay and ran the engine until the engine died.
Removed the skid plate (4 13mm head bolts)
Loosened the front two 17mm head tank bolts, and placed a floor jack w/ 2X4 under the tank center and removed the belly band.
Removed the front tank bolts and used 4 tie wraps to secure it to the skid plate mount (to act as the "hinge" for the tank as suggested).
Lowered the rear of the tank just enough to loosen the fill and vent hose clamps, and pulled the hoses and hooked them out of the way.
Lowered the tank rear some more, unplugged the electrical connector on the tank, and after cleaning around the pump assembly (It's closer the the rear than I imagined) and tried to remove it. The semi-rigid black plastic hose was in the way, and started kinking. I couldn't disconnect it from the green fitting on the tank, and ended up breaking the brittle gray plastic retainer (Uggh!). Surprisingly, the assembly wasn't even well sealed where the hose plugged onto the fitting. It was a very loose fit, so was not "air-tight" at all.
I then removed that hose completely (cut down the side of it where it is shrunk over the metal tubing on the frame and remove it-you'll never just "pull it off').
Then the pump assembly easily came out and I laid it on the spring as suggested. The pump is retained by a clamp, so after undoing it, I removed the factory hose clamp at the regulator above, and the electrical connector (depress a very small black tab and pull), and selected/installed the proper rubber end cap from the two selected from the Bosch replacement pump, and cut a piece of the new fuel hose to match the old one and installed it on the pump using one of the new supplied clamps on the pump, and re-used the worm drive clamp at the top. The pump comes with an electrical adapter harness, and I installed this between the new pump and the old harness.
I was careful to mount the pump oriented so the new filter sock (snaps on) didn't obstruct the float travel, BTW.
I jumped the two inner FP relay contacts so the pump was powered to make sure the pump was fully operational for obvious reasons. It initially drew 10a then immediately dropped to 5a (same as the old pump). I ran it maybe 5 seconds.
The tank gasket stuck to the tank, and it has to be fastened to the pump top, so I reinstalled it, then re-installed the pump assembly, securing it with the original bolts.
I then used about 16" of 3/8" low pressure gas line (7/16" would have been better) and a couple of clamps to replace the semi-rigid line I had damaged.
As they say, replacement is the reverse of removal, making sure all of the bolts were torqued properly.
With the vehicle on the ground, I again ran the pump for about 15 seconds using the jumper to purge out any air, and cranked it. It started immediately and ran smoothly, so I drove the 1/2 mile to the filling station and filled the tank. I don't know how many gallons remained in the tank, but it couldn't have been much, because I could easily lift the aft end by hand (the front was hinged on the tie wraps), but the tank (marked 24 gal, but in the owner's manual I think says 21 gal) took 19 gal to fill it to the neck.
The job took longer than it seemed like it should have, and it was nice to have a helper to hand me tools and such once I was under the vehicle (space was very tight), or moving the relatively heavy skid plate out of the way, and back into position. I'd allow a total of 3 hours "just in case," like my parts store run for the fuel line, and, of course, lunch. Add an hour if you have a helper just because chatting/visiting takes time, and makes the job more pleasant.
Thanks again to Koda2000 for his suggestion of leaving the tank in the vehicle.
BTW, I had the proper Lisle tool to remove the fuel line from the external fuel line, but even pushed in to where I'm sure the clips were released, we could not get the hose off. I even depressed the Schrader fuel rail valve (Yes, fuel WILL come out, so don't do it on a hot engine) thinking maybe fuel pressure was to blame, but no dice!
I was going to replace my fuel filter, but it was late, and after the failure to get the hose off the tank, I just didn't want to mess with it. Another day, perhaps.
