Crankshaft Mysteries - Belt pulley bolt torque specifications needed. | Ford Explorer Forums
INOV8TN
Salisbury, NC
1994 2.3 L 2WD Ranger
Hi all -
I can't seem to find the spec in my manual.
There wasn't a lot of resistance taking them (4 bolts) off (20-30 ft-lb?).
This is for a 1994 SOHC 2.3 L MT 2WD Ranger.
Also, would I be OK using some blue locktite on them?
Thanks!
- Bill
the crankshaft pulley bolt should be betweeb 21-28 ft lbs. of torque
and the crankshaft pulley and hub assembly bolt should be between 103-133 ft. lbs. of torque.
Crankshaft mysteries - Thanks! What about the Loctite?
Hi and thanks again.
Any thought(s) on using Loctite on the pulley bolts?
i wouldn't bother with loctite on the bolts. as long as you use a torque wrench you should be fine.
Thanks! Wow! What a great response! Thanks again!!!
welcome.
Friendly and Generous Group
Thanks for the 'Welcome'.
I joined, posted a ques, and got great answers in less than an hour.
Hope I can contribute some day.:)
welcome
OK, Whatever works
...You can find some other useful Ranger info here...;)
Dead Link Removed
Thanks!
Looks like some great info.
