DavidInMi
- April 1, 2019
- Sterling Heights, MI
- 2001 Explorer Sport Trac
Hello forum!
I am new to the forum. I did search the forum prior to posting this but I couldn't find an answer.
I have a 2001 Sport Trac 4.0, it's my wife's vehicle. We have owned it since new. ~175K on it. Two years ago we started to have issues with two of the tires losing pressure. Turned out to be corrosion on the inner lips of the rims. I had the tires broken down, rims sand blasted and power coated and installed new tires. While that was going on I decided to do some rust repair on the running boards. Got started on that and my father passed away in another state. So, past two years have been busy selling houses, moving Mom back to Michigan, getting her in a condo, etc. I started the truck every two to three months just to keep it lubed up. I go to start it in January and it won't start. It would turn over but not fire. I shot some starting fluid into it and it fired. That, in combination with not hearing the fuel pump running led me to believe it was the fuel pump. I was also concerned given how old the gas was getting from sitting. So, dropped the tank, drained the old gas, installed a new pump, complete assembly from Rock Auto. Installed a new fuel filter. Also have been doing some other maintenance while it was up in the air. New cat back stock exhaust system, new rear shocks, new pinion seal.
Anyway, the problem. I get it all done and go to start it up yesterday. Turn the key, here the new pump fire up. Runs a short time to build pressure then stops, I start the engine. It fires and immediately starts to surge all over the place, up to 3K, down to almost stalling, back up, back down. I tied this half a dozen times leaving a few minutes between attempts. Everything I've read on this forum (and others) says it could be a vacuum leak, bad fuel pressure sensor, or perhaps a bad ground. Maybe even the pump assembly I got was bad.
So, I plan to get a fuel pressure gauge from the local auto zone to check the pressure. Not sure how that's going to work since I can't get the RPM's stable at all. I'm also going to check for vacuum leaks. Pull the vacuum line off the fuel pressure sensor and see if there is any fuel in the line. Check the Oil for fuel. Clean the MAP sensor.
Any other suggestions? Is it possible since I had the system open that it needs to be purged? It being a 2001 I understand it was an interim system. It's the one line fuel filter system.
Any thoughts would be appreciated.
