samrebel
- April 20, 2004
- Cincinnati, OH
- 1996 XLT
After having to replace the sending unit for my fake oil pressure gauge, and reading the trouble others have gone to in order to make it a real gauge, I was thinking about installing a gauge cluster in my '96 XLT. Then I started thinking about what is used in one of my other interests: high performance fighter aircraft. In the latest generation most gauges have been replaced with Multi Function Displays (MFD) LCD screens which show anything from weapons targeting info to engine data. A germ of an idea began: Ease Diagnostics makes an OBD-II scantool software program which can display tens if not hundreds of engine and other parameters in real time. If I remote mounted a computer running this program, spliced a hidden OBD-II connector in to plug the Ease cable into, and run a cable from the S-video out from the computer's video card to a dash-mounted LCD, voila! Imagine: having access to real-time timing advance to see if you need higher octane fuel when climbing or towing! The possibilites are unlimited, but it would be expensive.
Have I gone crazy, or is this a good idea?
