wifesmountaineer
- September 9, 2008
- las cruces, nm
- 97 mountaineer
ok, this is kinda crazy.
1st - any help is greatly appreciated
2nd - 1997 Mercury Mountaineer, all wheel drive, 5.0, 4 dr, auto, 78K miles, dry climate, never crashed.
3rd - if the motor is off with the ignition on or acc, everything works just fine
4th - with the motor running the passenger and both rear windows work fine
5th - the driver's window works fine going down holding the button or using the one touch feature
6th - here's where it gets weird. When rolling up the window, the relay clicks and the window jerks. up, then stops, then up, then stops. If I continue to hold the button down with the window all the way up, the relay continues to click. tick-tock-tick-tock like a blinker relay. Along with the window motor starting and stopping, all of the interior lights blink along.
7th - sometimes the relay just starts clicking all by itself. No button pushing or anything, just driving down the road and it starts opening and closing. Sometimes the window gets a mind of it's own and just rolls itself down. These random acts tend to happen when it's cold (65 degrees) in the morning
8th - I tried replacing the relay with no improvement.
9th - I've looked all over for the same problem and can't find an identical issue.
10th - Did I mention that this is my wife's car and I need to get it fixed if I want to sleep in my bed again!!
Thanks for the help!!! Forum Posters are the best!!!
