kend9090
- April 28, 2014
- Stockton, Ca.
- 2020 Explorer ST
Explorer 2005 EB 4.0L cruise control not activating. No cruise light on dash.
I do not use this frequently but noticed it stopped working.
Checked switch on brake pedal it is OK.
Looking through the forums, I Checked Deactivation sensor on the master cylinder and it has 3 wires coming out of it. Mounted on underside of MC. I'm assuming that one wire maybe for Advanced trac RSC? If unplugged I get the Advance Trac light on the dash. I see no change in resistance when stepping on brakes. I can't find a schematic that is readable online so troubleshooting from forums. They seem to point to safety deactivation sensor on MC since Cruise light on dash does not even turn ON.
I see 2 wire deactivation sensors listed online but do not see a 3 wire?
resistance readings: Pin 1 Red wire==>Pin 2 Red/wht is 182Kohms.
Pin 1 Red wire==> pin 3 White/red is 6.45kohm
White/red==>Red/wht is 192K ohms. No change on any when brake is applied.
Am looking at the correct area?
If I look at replacement parts online it looks exactly like sw-6349 and says that it is the part for a 2005 Eddie Bauer but mine has 3 wires?
