cruise control not working | Ford Explorer Forums
fordexplo01
Windsor Colorado
2001 sport
So my cruise control wont work the left side the on off switch lights up and works and the right side doesnt all the set and stuff. when i bought it it worked but didnt light up so i took it apart to check the bulb and put it back in and now it wont work is there a fuse or something i can check or do i need to go buy a new module
no i dont everything works but the set accel and decel module
k thanks
welcome once again
similar cruise control problems
Brooklyn Bay, what you describe is what I am experiencing on my 95XLT. I have no horn and no power on to both cruise control switches. What is a "bad clock spring" and how do I replace it? I know how to remove the cc switches and airbag but still haven't gotten around to it. Also, I assume airbag is working since inflation light comes on when vehicle started and then goes out as normal.
Any suggestions before I order new cc switches:us:
The clock spring is the part with the rotary contacts. It's a fragile part. You have to open the steering column, and remove the steering wheel with the air bag to get to it. Disconnect your battery, and wait a minimum of 10 minutes for the power in the air bag module to drain. Your air bag could deploy if you do it too soon.
clock spring question
BB,
Before I crack this open, had a few questions. Do you think that the spring broke or just stop making contact? So the cruise and the horn make contact through the spring? I assume that Ford has the replacement part and I don't have to lurk through junk yards.
Thanks for shedding the light on an area that I wouldn't of looked at.
FTM:us:
Check the switch on the master cylinder too.
It's known to fail and when it does, cruise will not engauge.
