bigapple
- September 11, 2006
- Baton Rouge LA
- '02 XLS Touring
For those of you interested in lifting/leveling your third gen. explorer, the site is www.coilsprings.com. When you go to the site, go to the bottom part where it says "custom" and go to request a quote. This alows you to ask a price for a custom set of coil springs, front or rear, to lift/level/lower your explorer. I suggest calling too, to explain to the person how you want your job to be done.
To install your springs, i suggest getting it done at a shop with a wall-mounted spring compressor. I thought i would be able to manage with spring copressors myself, but the compression rate is so high because these springs are made thicker for a small area.
The custom springs won't actually make the strut bigger, but rather adds more compression in the spring to push it further down, resulting in a lift. If you're planning to want to lift more than about 3 inches, i suggest looking for a new set of control arms and/or a bigger set of struts. 2 inches wasn't all the way to level but it definately gave my explorer the obvious 4x4 look. If you are to use this to level your explorer, I would suggest using 3 inches instead of 2.
