Paul
- August 18, 1999
- Grit City, Washington
- '94 “Sport”
- Callsign
- KK7CSO
I have the Rancho 2 1/2" Suspension Lift and want to upgrade the suspension to fit 33" tires without starting from scratch.
What I intend to do is swap out the 2 1/2" front coils with 4" coils and do a spring-over in the rear. I want to be able to continue to use the Rancho drop down bracket, radius arms, pittman arm, and shocks (instead of purchasing a completely new kit). Now here's the issue: A regular spring-over would put the rear end about 5+" (e.g., Superlift 5.5" Kit); is it possible to do the spring-over keeping just 2 (of the original 3) leafs per side in the rear?? Or would this conversion not be feasible??
Pinion Angle?
Drive Shaft Length?
Axle Wrap?
Anyone with suggestions or ideas, I'd appreciate your comments.
Paul
Pinion Angle?
Drive Shaft Length?
Axle Wrap?
Paul
