jsexplorer
- November 18, 2011
New member here. I've got an '08 Explorer with about 40K miles on it. It has started to grind in the front end when 4WD is engaged and making turns (as in backing out of the driveway, or at a stop sign). Worse when making left turns. Seems OK going straight. Doesn't do it in 2WD.
Took it to the dealer and they compared to another '08 that was in for service. It made the same noise, but probably worse, as I was in the vehicle for the test drive. Their conclusion was it's normal. My conclusion was they have 2 vehicles that need to be repaired with the same problem.
I crawled under the front end today and checked for play in the CV joints. Both front axles have some slop when I twist the inner CV at the transfer case connection. Enough play to click when I rock it back and forth.
Can anyone tell me if this is normal wear, or should they be solid and not move at all? When I tried twisting the drive shaft, there seems to be no movement at the outer CV. That's why I'm suspecting the inners are wearing and causing the noise that I'm hearing.
Thanks
Thanks
