Aussie Explorer
- June 3, 2005
- Western Australia
- 98 XLT
Ok I have a “Little” diff oil leak from the front diff “Dana35”. It is coming from behind the Flange assembly on the front diff. It look’s like it is just a rubber seal that need’s to be replaced would I be correct in assuming this.
Is it straight forward to replace, I.E Unbolt drive shaft from diff, Remove flange, Pull seal out and push new seal back in?? Or is it a little more complex.
