- August 1, 2008
- MO MO
- 94 & 95 XLT's
Weirdest thing. When the A/C is on, 3 of 4 gauges act up.
Switch A/C on..
Oil pressure gauge goes up.
Temp gauge goes up.
Volt gauge goes up.
Turn the fan from low to high, all three go even higher. Start from low fan speed, and go up one speed at a time, they all go up following the fan speed selection.
Turn the fan speed from high to low, all three go down following the fan speed selection.
So, the higher the fan speed is, the higher the gauges read. The lower the fan speed is, the lower the gauges read. The needles move instantly up or down with the fan speed switch.
Is my Cluster messed up? Is there something else that would cause this?
Thanks in advance for any ideas here.
Switch A/C on..
Temp gauge goes up.
Volt gauge goes up.
