Daytime running light issue. | Ford Explorer Forums
my fordaerostar1
canada
92 aerostar
Good evening to all.....Yep another person seeking answers.....:)
I have a 1992 aerostar and my day time running lights (DRL) are not working.
I have located where the module is but don't know which one it is???
It is on the left fender above the battery -There is a cover and under it is
four or five modules.
Any info would be muchly appreciated.....:cool:
Thanks ,Dave H
p.s.I did check the fuse in the panel for the DRL and it is okay
Uh oh... Another Aerostar member for Mike... ;)
Welcome Dave!
Stay tuned- I'm sure BrooklynBay will have an answer for you when he sees this one...
Welcome to this forum! I've renamed, and moved your thread to the Aerostar section. Daytime running lights are installed in Canadian versions such as your model. The relays you are looking at have nothing to do with it. You are looking at the fuel pump relay, PCM relay, and the compressor relay. There is another thread in this section on daytime running lights. Check this link: http://www.explorerforum.com/forums/showthread.php?t=231311
