BigBlueBrick
- April 11, 2020
- Los Angeles, CA
- 1998 Ford Explorer XLT
So, I've really got 2 issues going on here with my 98 and I'm unsure if they are connected. The big one, if you didn't already guess from the title, is that I've got no blinkers when I move the multifunction lever (which I just replaced). I get absolute zip zilch nada both ways. When I move the switch in either direction, I can hear the relay under the dash make an initial click, but the lights do not illuminate inside or outside and the clicking does not continue. I have no blown fuses and I went through the power distribution box on the fender but nothing seems amiss there. Admittedly I haven't checked the relay box under the airbox because I didn't find a diagram labeling what they are for, so the issue could still be there. My hazards work as they should and did so before I replaced the MF switch. Doing so actually yielded no improvements. I have tried to see if the issue stems from the tilt steering by tilting it back and forth as well as checking the plugs on the column but that yielded nothing. The ONLY life that I can extract from the blinkers is if I hold the brake pedal down and move the MF lever slightly to engage the right blinker which results in the right blinker lighting up solid. The sweet spot to make this happen is very small. This leads me to assume that the blinkers and the brake lights are crossed at some point.
This leads me to my second issue, which is the brake lights flicker while they are on, both with the headlights and when the pedal is depressed. I have also noticed that the third light at the top is slightly illuminated when the brake lights are on with the headlights, which I know should not be the case. I feel that the flickering lights could be attributed to an alternator on its way out because the gauge on the dash is a bit on the lower side, but that might be a stretch given that none of the other lights on or in the explorer seem to flicker. I read somewhere on the forum that the flickering lights could have something to do with an issue with the anti-theft system, but I'm unsure.
What are your thoughts on this? Am I nuts or do these two circuits seem to be crossed in some way? I have a new relay coming in the mail from Rock Auto, so hopefully, that ends up being the fix for the blinkers. It still doesn't explain why the blinker lights up solid with the brake pedal. I'll look for that thread about the brake lights and the anti-theft issue and stick it in this discussion.
