Ricky B
- May 30, 2010
- So Cal/Baja
- 1996 XLT Control Trac 4x4
Hey Folks, been trying all morning to keep the 10 amp #26 fuse from blowing on ghe Daughter's '96 4.0 XLT 4x4.....but to no avail. I get 12 volts on the rear most slot with the key on, no voltage with the key off.....but no matter what I shake, unplug, disconnect or whatever, I still have continuity between the forward fuse slot to chassis/body ground. Key on, key off or even while running. Am I correct in thinking that continuous continuity from that outbound slot indicates a dead short somewhere? 'Cuz I've been through eight fuses today (from 10 amps thru 25 amps) after disco'ing each component on that circuit, then intalling another fuse to see if I can isolate the problem.
I've removed the b/up lights, then the t-case shift motor harness, then the two connectors at the front drive solenoid, then the transmission range sensor coupler, then finally the o/d push button & the two wires from it that usually wear on the steering column casting. But none of those have solved the fuse blowing problem. Any ideas and/or insight would be greatly appreciated. ....
Cheers,
Rick
Cheers,
Rick
