Naasau
- January 2, 2007
- Denver Colorado
- '93 Explorer XLT
Not sure if this is the right place to post this thread or not, but here goes. My engine is half-dead and though I pulled the codes and looked up the definitions (posted below), I have no idea what to do next.
Okay, so my X was running oddly off and on, with the check engine light flashing about once every few weeks, and she was leaking oil pretty badly from the valve cover seals. I took them off, cleaned everything up, and put her back together, she then started running terribly whenever the engine was under load and the exhaust smelled badly of fuel, so I assumed that not all cylinders were firing, and since the plugs are less than 2 years old, and the cables about 4, I replaced the coil pack, which didn't fix anything. Got a code puller and retrieved this:
212 - c - Loss of ignition diagnostic monitor signal/ SPROUT circuit grounded
232 - c - (Trucks Only): Electronic Distributorless Ignition System (EDIS) Coil 1, 2, 3, or 4 circuit fault
To me that means some kind of computer signal failure of some sort? Does anyone have any ideas on how to go about tracking down / fixing this problem?
