Hi All
Sometimes I have problem with too low engine oil pressure. Sometimes when RPM go down below 500RPM my oil pressure indicator shows almost 0 (it is analog gauge with tip). It happens when I try turn turn steering wheel when car is stopped or changer gear to reverse.
Sometimes that extremely low pressure occurs also when car is leaning to the left. Sending unit is new. What is your advice - should I change oil pump?
The car is 1999 year, 4.0 SOHC.
Marcin
Marcin
