delete auto pwr dn on windows | Ford Explorer Forums
wpurple
CT
97 Explorer
Has anyone had the desire to delete the auto pwr down feature of the pwr windows? Sometimes I just want to put the window down a little and it goes down all the way...just a bit of a pet peeve. Not sure if anyone tackled this before????
Thank,
Kurt
all you need to do is just hold the button down a little longer.
On my 96 the autodown is through a special relay inside the dash. You could find this and delete it. However, on your 97 it may be part of the switch itself, you'd have to get a non-auto switch if so.
Flip the switch around so it's Auto UP! :D
(I don't know if that would work or not.) But if you can switch the Auto one with a Normal one.. I'm sure you can switch a normal one for an auto one.
Is the auto feature in the switch itself, or does it include extra relays. Any ideas on how to get this in a 1st gen. I assume the switches are entirely diff.
Auto Up would be nice.
Like I've said before, in mine it's in a relay. In later ones it's in the switch and you can just swap the switch out. Dunno which in a 97.
I tried adding a spare relay to auto down the pass window and it didn't work. It's a wiring nightmare.
it is the one touch down relay.... you could i guess cut the wire that is coming off the GEM module that is on the left side of the stereo...dont know what wire yet, but i will look into it...cuz i know there is one wire coming off of that that completes the one touch down relay circuit...
it is not the switch, i wanted the auto feature for my passenger switch, it didnt work, i need a one touch down module for it...
97 schematic
2nd page (for sport)
